OK so I have a 14 ram 1500 2wd with the crap upper arms. I see lots of companies that sell them for 4wd's. Seen some people go to junkyards and find 12's with low miles and use those.
What is the difference between the upper on a 2wd and 4wd upper. I would like to buy new ones since my truck has under 1k miles but I plan to level and also lift it and if I do the full lift its a spindle and a spacer which the spindle is OK but the spacer will cause a problem from what I have seen on many trucks one at a local 4 wheel parts getting a spacer on a 4wd and now the upper is trashed and pro comp told them to get a aftermarket upper. So where can I get a 2wd and what is the difference between a 2wd and 4wd arm?
