Hello, I have a 2014 2500 (bought it in Dec. 2014, so just over a year old and under 9400 miles on it). I got it serviced at 7500 miles back in November for its first service and when I got it back, the dealer didn't rotate the tires because their service just includes an oil change, but I could take it back to them and pay for a tire rotation... That's when I found what I think is a problem. My right front tire is wearing the outer edge of the tire more than the left tire, probably 2-3 times faster. For those that have Transforce A/Ts, after 7500 miles up front, the front right tire was almost worn down to the second stage of the tread bar (the part that is about half the height of the full tread). That tire got put on the left rear and now has about 1 inch of tire that doesn't contact the ground.
The truck drives perfectly straight, returns to center, no bad bump steer or death wobble ever. The driver's tire is wearing great on the front. I figured I would give the rotation a thousand miles and watch closely to see what a different tire did, just to rule out the possibility of a bad tire. Well, the tire now on the right front is doing the exact same thing at the exact same rate, and the drivers side looks great, just like it did before the first rotation. Has anyone had anything like this on their truck? I guess I am outside of the 12 month rule for Ram covering an alignment check, but if it is caster, then is there really anything in an alignment for these trucks that will correct it? Wouldn't it have to be a bad ball joint, wheel bearing, or else an axle housing that was out of wack from the factory? I don't drive the truck hard, it is all stock (as you could probably guess since I'm still running the stock Transforce AT's.. ) I saw some stuff about an eccentric sleeve in the top ball joints on older Dodge Rams, do the newer trucks have anything like this?
I guess I'm wondering if I should even bother with a dealer on this (i.e. will Ram/Mopar help me out on this in anyway with Warranty?), and I'm hoping someone else has resolved this same issue first and can give me some pointers.
If this belongs in another forum, please let me know and I will try to get it moved.
