1 - 3 of 3 Posts
Discussion Starter #1
I'm confused as the correct way to use the Auto Leveling. I just purchased a 2015 Laramie Crew Cab SB 4X4 with the rear air suspension option. What is the correct procedure to hitch and unhitch to a 5th Wheel. I tried pushing the Alt Towing Height button and back under the pin and lower the 5th wheel while the truck is running. Do I tow in the Alt Towing Height or change to Standard Height?
When unhitching, do you turn the truck off when lowering the 5th wheel jacks or leave the truck running and push the Alt Towing Height button?
Thank you in advance.
Discussion Starter #3
What I found that works good is I leave the truck running, drop the landing gear and extend the legs making sure both feet are carring weight, but don't extend too far as to lift the truck. I disconnect plug and safety cable, release hitch lever and get in truck and drive away. Works smooth as silk. I then push the button to return truck to normal ride height.
1 - 3 of 3 Posts
