1 - 3 of 3 Posts
Hi everyone
Check engine light came on last week and diagnostic gave the code P018C (fuel pressure sensor B circuit)
I called my after market part store and he said that the fuel pres mobdro sure sensor alone was not on the catalog, only the entire fuel pump assembly (which I guess has the sensor built in) https://pnrstatus.vip/
But I’ve found videos on YouTube of people replacing the sensor???
Does anyone have experience with this? Do I need https://sarkariresult.onl/to replace the pump?
My 2013 Ram 1500 3.6L threw that code a couple months ago. Dealer wanted $500 just for the part so I went online to moparonlineparts.com and found the part for about $390. Your model may call for a less expensive part hopefully. Was way overpriced but couldn’t find any other alternative. Did not replace the fuel pump. Fixed problem. Search that code on this forum for more info.
Super Moderator
P018C is not the code for the one in the fuel pump. The part is (like $54 IIRC) and takes 10 minutes to replace. Here is my thread from when it happened to me:
1 - 3 of 3 Posts
