1 - 3 of 3 Posts
Discussion Starter #1
Has anyone tried or heard of anyone removing the bench off a 2015 Ram 1500 crew cab and swapping it out with captains chairs?
How good are you at fabrication? Seat mounting is not rocket science so take a look at your front seats, measure them up and see if the size is about what you want back there. If so, get a second set and wire up the seat heaters and adjustments. You'll lose some room, I would guess, but it's a start to see if it's possible.
I've been putting modern seats in my old cars for years and it's not bad if you can weld and fabricate. If the Ram seats are too big, look at mid-size cars and aftermarket ones like Procar.
Using the same seats as you have would keep you from needing to recover the interior.
Discussion Starter #3
Thanks I figured I would have to fabricate. I thought maybe some company had already thought of it and had brackets made. But appreciate your answer.
1 - 3 of 3 Posts
