1 - 11 of 11 Posts
Discussion Starter #1
Hey. Guys.
On my 2015 ram 2500., I'm looking for the + parking light wire. Does any know the wire color and location of this??
What are you trying to do? Do you want to locate it up front by the headlight? Or by the switch maybe.
Discussion Starter #4
I am trying to hook up that smoke section to the parking lights. I just don't know where a parking + besides up high in the ecm
Man those look so much better than the Ram tow mirrors. I wish so bad they would redesign the factory ones to something like that.
I'll do my best to look on a wire diagram at work tomorrow. Do you have the daylight running lights working?
Discussion Starter #7
They don't have an option wire for day time running. Unless it's built into that factory harness. I thought about am accessory wire. But this would mean that they would be on everything the truck is running.
If you cant read it when you blow it up let me know. There is probably 3 wires for the bulb. One ground, one a blinker and other should be your target. May have to pick it up by headlight and run a wire back. I tried to pick up power for something off headlight switch, but only like 3-5 v anywhere by switch. It has to go to the module then signal comes out 12v.
1 - 11 of 11 Posts
