All,
I have a 2015 Ram Sport with hemi and 3.92 axle ratio with factory hitch and receiver/tow package. Based on this, I have trailer max tow capacity of 10,160lbs and payload of 1530lbs. I recently bought a travel trailer with a 5900lb dry weight and a 890lb tongue weight. I figure once TT is loaded, I will have tongue weight closer to 1000lbs. I went to hitch the trailer up the other day so I could work on putting on my weight distribution hitch, but my truck sank so much, I couldn't even take the trailer off the jack. Based on all the info, I would have assumed my truck would have at minimum allowed me to place the TT on it so I could drive it onto a flat street so I could set up the WDH.
Some have suggested upgrading my coils with a higher rated coil? Others have suggested getting air bags but all the research I have done, I want the WDH to do most of the work and airbags, if not applied properly, counteract the work of the WDH.
I know the simple answer is to upgade the truck but with costs nowadays, and based on specs, I should be able to use my RAM with a few mods? I appreciate all the advice in advance!
