1 - 1 of 1 Posts
I need an accurate wiring diagram for the Camshaft position sensor for this exact truck. Very mixed information throughout the years. 3 wire sensor, I'm reading 5v power on one side, 12v ground in center, and 5v ground on the other side. I need to know which wires go where because I believe that there should be 2 powers and 1 ground instead of 1 power and 2 grounds. I believe that 5v ground is shorting to ground and is actually supposed to be positive voltage but I need an accurate diagram or someone who has the exact year and motor to confirm. 5v power is believed to be reference wire, center ground, and whats showing as 5v ground is supposed to be my signal on the outside. Please correct me if wrong, Thank you.
1 - 1 of 1 Posts
