1 - 1 of 1 Posts
Discussion Starter #1
Went to start my truck, wouldn’t crank, all lights flickered and acted like it had a dead battery. Jumped it off, started right up. Then I went to leave and it died and gave a service shifter message. After it died it began flickering all the lights again. Tried jumping it off again and it didn’t work. After several cycles of the ignition trying to start it, it locked the key fob in acc or run only. i Changed the battery, the Old one tested at 95% charged with a dead cell and only 80 CCA. New battery in, lights don’t flicker BUT, the information panel doesn’t display anything except mileage, Seat belt light and key in ignition as well as the uconnect Screen not working or anything else aside from the lights, horn and door locks. have had a rodent issue before, the truck has a new engine harness and no signs of rodents visible. Any ideas what this could be or where to start looking. I have checked all the fuses and visually inspected all visible wiring and can’t find an issue.
1 - 1 of 1 Posts
