I bought a used truck drove it off the lot 500 miles home noticed the fuel gauge stick during a fill up and started reading normal after a quick pit stop. I drove to work the next day no issue sat in for lunch no issue and then when I got off work my truck would crank but would not start. The pump has been replaced now and the issue remains (the mechanics found the pump that was installed was actually just hanging loose inside the tank so it needed to be replaced regardless) the fuse for the pump motor was crispy but not blown when I went to check it and the last thing we could determine was the relay has fried. I have been scouring for a bypass or something to fix the relay but it appears that option is only viable up to the 2016 model.
Any information or suggestions other than spending 4-500 on a new TIPM and having to get a dealer to flash it to work (this is horse shit) would be a real life saver!
