1 - 4 of 4 Posts
Discussion Starter #1
I’ve noticed oil spots in my drive way a few times over the years I’ve had it in twice and they said there isn’t any leaks, last time I took it in April because my bumper to Bumper ran out end of May and they said it’s fine. Well today I noticed a bunch went outside crawled under and saw oil drops on a few spots under the oil filter, hanging off of stuff. Should this be cover under my power train warranty? I checked my oil stick and it half way down the checkered spot. I doubt my truck would be burning oil with so Little use? It’s been hot, could that cause leakage?
Either a leaking filter OR whoever changed the oil last just didn't clean it off good at all - which would explain intermittently seeing oil drops.
When you change the filter, the oil comes out and drains onto the parts below - mostly the steering gear.
1 - 4 of 4 Posts
