1 - 2 of 2 Posts
Hi!
Not sure whether to level or lift my 1500. Is there a recommended kit for each option? I always thought leveling put extra wear on front end parts. I like the look of a lift kit. Nothing too insane for height.
Anyone care to give their opinion on both?
Thanks!
Super Moderator
Kind of depends on why you're doing it. If you just want a little more clearance up front then a level is probably the way to go; if you want 37" tires you need to lift. If you frequently tow and haul then neither is the best option-realistically there's not a lot you can't do with the 33s you already have.
Bilstein 5100s are the consensus here for best leveling kit; BDS is the best lift
1 - 2 of 2 Posts
