1 - 5 of 5 Posts
I have 1,500 miles on my Ram 1500 and I am having brake problems, at times when I brake it will pull sharply to the right so bad that if I removed mu hands from the wheel it would probably spin out, some times the pedal is too soft like a master cylinder is going out. brake fluid is full, pads are good. any ideas?
Super Moderator
Agreed with airforce, you're under warranty and this could be a number of things causing it
Discussion Starter · #5 ·
brakes
update : the dealership had to replace the brake booster and do an alignment, they could not duplicate the pulling to the right when braking but at least I have power brakes.
1 - 5 of 5 Posts
