1 - 1 of 1 Posts
I added new rear glass with defrost and power sliding window. I’m under the assumption that the defrost for the rear window runs on the same circuit as the defrost for the heated mirrors. If not will I have to run separate wiring harness for the defrost function? The powered rear sliding window I’m assuming is controlled by a rocker switch that reverse ms the voltage to open and close. Is there a know place to tap this voltage off the dash and wire it to the back window. If so where is it. I noticed when I pulled off the side panels there are white plastic connectors there with only a few wires attached. Is it possible that all I have to do is run a wire from each connector to the defrost connector on the glass. If anyone can provide me with a schematic so I don’t have to cut and splice that would be great. I would much rather plug and play.
Motor vehicle Bumper Automotive exterior Automotive tire Gas
White Automotive tire Vehicle door Automotive exterior Motor vehicle
Vehicle Automotive tire Motor vehicle Hood Bumper
1 - 1 of 1 Posts
