I have a 2020 RAM Bighorn, purchased in May. Now that the weather is turning cold, there are times where the remote start fails to operate properly if it sits for 24 + hours. Is this normal?
I have a 2021, no issue here like you describe.I have a 2020 RAM Bighorn, purchased in May. Now that the weather is turning cold, there are times where the remote start fails to operate properly if it sits for 24 + hours. Is this normal?
It could be a main battery issue. I may call AAA and get them to provide a free test. I do not have a tester, or I would do it myself. Is the battery covered under the 3-yr warranty that came with the truck?I have a 2021, no issue here like you describe.
I thought it was 12 months and under 12K milesIt could be a main battery issue. I may call AAA and get them to provide a free test. I do not have a tester, or I would do it myself. Is the battery covered under the 3-yr warranty that came with the truck?
Maybe that is what it is for the battery. I will be calling tomorrow and asking, as I have a floor mat recall and will need an oil change.I thought it was 12 months and under 12K miles
I usually never get it below 1/2.Are you over 1/4 in your gas tank? Remote won’t work if your not.
Yeah mine won't work once the low fuel warning comes on.Are you over 1/4 in your gas tank? Remote won’t work if your not.
This is what I did. The battery voltage rose to where I think it is supposed to be, right above the middle mark. It took 3-4 seconds to get to that spot on the meter (in-dash version). The dealership is now doing an overnight battery drain test. They wanted to say it was the dash camera, but it was installed in June, and never had any issues until it got cold out around Dec 1st.Mine randomly wont start. Today I tried from Alexa and saw the lights flash but it did not start. I went to the door and pressed the fob twice and one flash...Just like what it does when the engine is remotely started and then I want to turn it off, so the computer thought the engine was running. Pressed the fob twice and got the the indications like it was going to start but it didn't, pressed twice again got the one flash like when turning it off.
Next time it doesn't start I'll turn on the ignition and look at the battery voltage.
