2025 Ram 1500
4 reading
33K views 140 replies 51 participants last post by  PowerJrod
For the last two weeks, I have been looking at 1500 RAMs in the Northeast. Not one of the two trucks (Laramie and Big Horn) would start at one dealership, and the same thing happened at another. I am going to purchase one, but will ask about this issue before I buy. I just thought they may have been sitting for three or four months. I have had two fords, two chevys, and now I am on to RAM. Hopefully better luck than with the latest Chevy.
That doesn't sound good. Mine should be arriving on the 11th. Hopefully I made a wise decision. I have had 2 fords, and currently I am on my second Chevy, which I lost my transmission with 84K. Anyways, now I will be a RAM guy. Hopefully, a happy RAM guy. My dealership is giving my a 15 year, 150 mile, bumper to bumper warrantee at no cost to me. I am sure I am paying for it somewhere.
My new 1500 night edition with 2,900 miles was cold dead yesterday morning in the Maine North Woods. On Monday we drove 3.5 hours to reach our destination. Less than 20 hours later, I went out to start my truck, and it was dead. Not even a light from anything. I got out my jump kit and tried to jump the truck. I got some dashboard lights, one click when I hit the ignition button, then everything started flickering, and then nothing. I grabbed my generator and a new battery charger. Got the generator running and charger hooked up. The charger said I had 4.4 volts from the AGM battery. I gave it a 30A charge for 30 minutes and brought the voltage up to 4.7 volts. I hit the jump start button on the charger and tried to start the truck. Same results as with my jump kit. Last resort, I had my boat battery in the back of the truck. Fortunately, the post were on the same side, but on the opposite side of the battery. I had to cut a lot of wire ties to get enough slack to hook up the battery. The truck started right up. I tied the battery in place because the battery bracket would not fit. I drove 4 hours home, right to the dealership. I called them on my way home and told them I was on my way. The said they had to keep my truck to run some test on the batteries. This truck has the large AGM battery, and a smaller one between the AGM battery, and the firewall. The little one is called the "stop/start" battery. They called today and said my truck was all set. When I got there, I told them I wanted someone with authority to explain exactly what happened to this $65K truck with less than 3k miles. I had two mechanics and the service manager explain what happened. The "stop/start" battery shorted out. Because of that, it drained down the AGM battery. I could not jump it, because with the "stop/start" battery shorted out, (it is either in parallel or series with the AGM battery) the AGM battery wouldn't take a charge. They said they have had issues with the "stop/start" batteries, but they can't replace them under warranty unless they fail. I asked them how I could get around this issue if it happens again. One of the mechanics said to take the positive lead off the "stop/start" battery, wrap it up tight with a rag (isolate the end of the cable), and then jump start the truck with my jump pack. I am not totally sold on this, but I take my truck off the grid, and AAA is not going to get me. I don't have the time to research the electrical wiring, but does anyone know what the "stop/start" battery does? Does it have something to do with coming to a stop, and the engine shuts off? I hope this helps someone in the same situation I was in. I sold my 2017 Chevy Silverado with a bad transmission, to get myself in a truck I can trust. My trust just went out the window.
Guess what folks? Exactly one month to the day, my 2025 RAM Laramie 1500 with 4,323 miles would not start again. I had been using it all day, and decided to put it in the garage. I hit the start button, and nothing. I removed and isolated the positive lead from the stop/start battery like the technician told me to do and tried to start the truck with my jump pack. All I got was a bunch of flashing lights and windshield wipers. I decided to disconnect/isolate the negative lead to the stop/start battery and try it again. The truck started right up, but I had a check engine light on. I shut the truck off and tried to start it without the jump pack to see what happens. The truck started right up. I drove the truck around all weekend with the start/stop battery completely isolated from the main battery. The only thing I noticed was when I brought the truck to a stop, the engine did not shut off. I dropped the truck off at the dealership this morning. I want to know what keeps shortening out the stop/start battery, what exactly does the stop/start battery do, and why do I have to jump the main battery when this first happens, but I don't have to jump it every time I shut the truck off.
I may have. I wrote two post regarding my issue. I have a 2025, 1500 Laramie with 4,300 miles on it. With 3,100 miles, I was at my camp in Northern Maine. Went to start it, and it was completely dead. I tried jumping it, charging it, but finally yanked the battery and put in my boat battery. Lucky that the + and - posts were on the same side. The truck started right up. I drove it 4 hours to the dealership. Ended up being the start/stop battery. It shorted out, and because it is connected to the main battery, it would not allow the truck to be jumped. I wasn't happy and spoke to the lead technician, asking what to do if this happens again, because I am not going to carry a spare battery in a truck I just paid $68k for. He told me, if it happens, to disconnect the positive lead to the start/stop battery, and isolate it. Well, one month the the day, it happened again in my driveway. No indication that it is going to happen, and I had been using my truck all day. I disconnected the positive lead to the start/stop battery from the main battery. Tried to jump it with my jump pack, and all I got were lights. I decided to disconnect the negative lead from the main to the start/stop, and try it again. The truck started immediately. I didn't know what would happen if I shut the truck off, so I tried it. The truck started right up. This was on a Friday afternoon, so I made an appointment for Monday. I drove the truck all weekend with no issues, except the stop/start function did not work, which I can't stand anyways. Again, it was the stop/start battery that shorted out. Hope this helps.
