Hello,
So I have a 2500 (CC/LB) on order. This is my first truck, and want to assemble an daily / recovery kit to keep in the truck at all times. Community feedback would be appreciated! (Over specced? Under specced? missing? Impractical?)
Among the list of things I am thinking about:
Daily:
Water, clothes, boots, snacks, etc. in a get home bag.
12"x12"x1.5" plywood board to serve as a landing pad for a jack
Polyester strap, 30klbs
Nylon strap, 30klbs
2.5" to 2" hitch adapter
2" hitch mount D Ring receiver
A couple extra 3/4" D Ring shackles
Front hitch mount (installed on truck)
Puma 12V 3/4HP 1.5g air compressor*
Air impact wrench
Sockets, wrenches, and other common tools
Ratchet staps, rope, etc.
Anticipating off roading:
12klbs winch (Front/rear Powerpole plugs will be installed on the truck w/ 1/0 wiring and appropriate fuses and switches)
hitch plate for winch
three >30klbs snatch blocks
air-down valves
hi-lift jack**
Ground anchor
I should state that my goal is getting the 7-8klb truck onto beaches, get to the end of trails, etc. Not interested in mudding, not likely to rock crawl.
I don't forsee forging new trails, merely getting me and the camera to remote places for interesting pictures. Do need to be able to go out in emergencies if snowmageddon hits.
* Unless anyone has suggestions for a tire compressor that actually works for 80psi. My current tire compressor that I keep in my Mazda struggles to fill my tires to even 40psi. Powering an impact wrench is a requirement for tire changing.
** It seems hi-lift style jacks, in addition to being near limit with 7klb trucks, are of limited use as 2500s don't have factory hi-lift points. Would a bottle jack or floor jack be better to carry around to assist with common tire problems?
Thanks all for the feedback / suggestions!
Daily:
Nylon strap, 30klbs
Air impact wrench
air-down valves
hi-lift jack**
Ground anchor
