Need some advice pls...
Working on a Friends 2500 that had a couple transmission issues. Since it has 108k on it, I assumed it was past time to service it. Also given the hard slam into first after a stop (intermittent) I decided to bite the bullet and replace the valve body and solenoid pack.
Put the parts in yesterday and waited for the RTV to dry over night. Oh and I pulled the neg. off both batteries.
This morning put in some new fluid, connected the battery terminals and jumped into try to start it. Display says it is not in park and can't move the gear shift. So I push the BTSI lever which allow it to move, but I lost control and it moved to far. Now I can't get it to move again.
Took the cable out of the holder on the tranny and the tranny lever does move but the display says it is in 1st. However, doesn't feel like it has detents but smooth movement forward and backwards.
Do I have a BTSI problem or a Tranny problem?
