In case you missed it the WK2 Trackhawk has been officially announced for a 4th quarter 2017 release-basically at the beginning of MY 2018.
http://www.motortrend.com/cars/jeep...9ea0204d30111b2f6438e&utm_medium=&utm_source=
Also mentioned in the article is that it will feature the ZF 8HP95 transmission, which is a 2nd gen ZF 8HP transmission. The Hellcat autos already feature a modified 8HP90, which in stock form is good to 664 lb-ft. From what I have seen the 8HP95 is not any stronger than the 8HP90 as the 8HP75 is compared to its 1st gen brother, the 8HP70 (8HP75 is good to 553 lb-ft input compared to 516 on the 8HP70); however the 2nd gen 8HPs have a wider range, are supposedly 3% more efficient and smoother.
The 1st gen 8HPs were introduced by ZF in 2008, the 2nd gens in 2014. The 2nd gens have a wider ratio spread of 7.81:1 compared to 7.03:1 for the first gen 8HPs; looking at the ratios (rounded to the nearest hundredth):
__________1st gen___2nd gen
1st:--------4.71:1-----5.00:1
2nd:--------3.14:1-----3.20:1
3rd:--------2.11:1-----2.14:1
4th:--------1.67:1-----1.72:1
5th:--------1.29:1-----1.31:1---^Underdrives
6th:--------1.00:1-----1.00:1---Direct drive
7th:--------0.84:1-----0.82:1---Overdrive
8th:--------0.67:1-----0.64:1---2nd Overdrive
Reverse:---3.30:1-----3.46:1
So not only do you get a slightly taller 8th gear for more efficient cruising (taller than the GM 8L90 8th gear of 0.65:1), but an even lower 5.00:1 1st gear, while keeping similar even spacing throughout.
That means that a Ram with an 8HP75 and 3.21s would be like having a 3.41 rear end on a Ram with an 8HP70; or an 8HP75 with 3.92s would be like an 8HP70 Ram with an outrageously low 4.16:1 rear end gear.
Or, to get the same first gear final drive ratio that I have with an 8HP75 you'd have to have a 3.02:1 differential; or 3.69:1 to equal a 3.92 geared truck.
To put it all together, now that Chrysler is using the 2nd gen 8HPs in one of their vehicles I think it is safe to expect them to appear in the 5th generation Rams, and perhaps the 2018 4th gens-though that may be a bit of a stretch. The spread in these transmissions will have a super low stump pulling 1st gear and an even wider range than the current 8 speeds-and even the GM 8 speed (the 8L90) and somewhat surprisingly the GM/Ford 10 speed. Check out their ratios:
__________10 speed___8L90
1st:--------4.70:1------4.56:1
2nd:--------2.99:1-----2.97:1
3rd:--------2.15:1-----2.08:1
4th:--------1.80:1-----1.69:1
5th:--------1.52:1-----1.27:1
6th:--------1.28:1-----1.00:1
7th:--------1.00:1-----0.85:1
8th:--------0.85:1-----0.65:1
9th:--------0.69:1-----------
10th:-------0.64:1-----------
Reverse:---4.87:1-----3.82:1
So stacking up the competition, the current 8HP70 already has a lower 1st gear than both the 8L90 (7.02 spread) and Ford/GM 10 speed (7.34:1 spread), and the 8HP75 has a similar top gear to the 10 speed and slightly taller one than the 8L90. Both competitors do have an advantage of a lower reverse gear and input capacity (8L90 can take 738 lb-ft, the 10 speed is 650 lb ft), but the capacity of all 4 transmissions mentioned in this post far exceeds the output of any 1/2 ton truck engine and an 8HP90 will match the 8L90 and would be easy to implement for Ram.
Looking at it subjectively, with all the hoopla about the 10 speed I expected it to have a wider spread. It is barely any greater than the 8HP70 that Ram has been using for 4 years and it seems that the two extras will just make it hunt more. There was an interview with one of the design leads at ZF a couple years back where he was asked how many gears he thought transmissions would get to in consumer vehicles. He replied that once you get past 8 or 9 you get to a point of diminishing returns, and this certainly suggests he was right.
