1 - 12 of 12 Posts
Ok so I've been thinking about leveling out my 2016 ram 1500 sport 2wd. It's got a pretty good rake on it, sits low in the front. I wanna level it out front to back. Rough country makes a 2in left spring and maztrac has a 2.5in spring. Both have good reviews. I was just wondering if anybody here has some experience with these products and if you look them.
How is the ride LoveCars69? Is it a lot stiffer? Trying to decide between the Maxtrac kit with Fox shocks or the rough Country Springs and possibly Bilstein or other shocks. There really is a lack of options for the 2WD folks.
Springs feel great looks nice. My only thing is cannot find a shock to fit for 2wd. Due to the factory shock not designed for the added lift. Does feel little bouncy over bumps is the only issue. Still looking to find a shock to fit the added lift going to 4 wheel parts soon to see what i can find
@coolvanilla if you find front shocks that fit our 2wd to compensate for the lift let me know. I found skyjacker shocks but they were wrong the base was not big enough the bottom bolts holes did not line up.
I have selected the N3 shocks by Rough Country.
THey come with the kit.
Discussion Starter · #10 ·
I sold the truck recently for financial reasons. I never leveled it but if you guys do end up leveling there are plenty of aftermarket shocks for up to 2.5 inches of lift. I personally would go with the bilstien 5100 shocks for the ram 2wd. Good luck.
After looking at that what you sent. Those are rear shocks not front.
I have a 2013 and thinking about using the rough country spring to level my truck and i have discuss with Bilstein 5100 shock about shock that will work with them, but i want to know how is your ride with this springs and if you have found some shock that work for you..... this truck is my daily driver and i don't to do the wrong thing in leveling it.
· Premium Member
You don't need different front springs to level your truck with Bilstein 5100s
1 - 12 of 12 Posts
