1 - 3 of 3 Posts
Discussion Starter #1
All, yesterday i tried to put a 3.5 inch leveling block in the front of my 2012 dodge 1500 quad cab. (I was going to put a 2 inch in the rear after.) We got it all installed but before we took the vehicle off of the jack stands i tried to spin the wheels with my hands and noticed that they would only rotate so much and then lock up. I want to know what is causing this issue and how i can fix it? Anything helps brothers.
Moderator
Take the 3.5" level out. That's your issue.... You can't run more than a 2.5" level (2.8" with Bilsteins) on a Ram. Anything higher and you put the A-arms and CV shafts at too steep of an angle and things don't work. Your CV shafts are binding which is why the wheel won't turn.
Check out the Guide to Leveling linked in my signature for all the information you need to know on leveling your truck.
1 - 3 of 3 Posts
