1 - 2 of 2 Posts
Discussion Starter #1
Needing info on whether the year is specific for a swap of a 3.7 , to a 3.7.
I have a 2002 Dodge Ram 1500, with a 3.7 engine and need to know which years of another 3.7 are compatible. A 2002 Liberty 3.7 might be available for a decent price , but I need to know if the years are specific to a good clean swap . As well as, whether the Liberty engine would be a problem to use as a swap. What years WON'T fit ? {Straight 3.7 to 3.7}
I won't think that there would be alot of difficulty from the library to dakota. Especially there the same year. I used a 89 block and head in a 91 s10. So I just kept the old block and head. Then looked at the difference between the two. Then swaped the parts I needed from old to new. So you shouldn't have to bother with that. Except maybe exhaust manifold. But that should work too.
1 - 2 of 2 Posts
