I like the 33x12.50 nitto mud grapplers and found a combo with 20x9 with 0 offset wheels.
Will i need a leveling for 33tires?
Will the tires stick out of bushwalker fender flares?
33" is standard diameter. As far as the width, my worry might be rubbing on the inner fender liner, not sure, may be able to trim. If you have Bushwackers, that should be perfect. You could do wheel spacers if they rub inside also.
my thinking was if a 20" factory wheel with +19 offset and a 1/4" spacer (which subtracts 6mm of the offset) will fit a 35x12.50 without rubbing, the new rim witch 0 offset won't rub for sure. (and the 33tire is a little bit smaller in diameter too)
or did you mean without leveling?
1 - 3 of 3 Posts
This is an older thread, you may not receive a response, and could
be reviving an old thread. Please consider creating a new thread.
