1 - 12 of 12 Posts
Discussion Starter #1
Hi guys,
Was wondering if there is an issues with mounting a 35/11.5/20 tire on the stock rim. I would have a 2.5 level kit in the front with a 1.5 in the rear. Want to know if anyone has come across issues like rubbing or anything. Pics would help.
Thanks,
I greatly appreciate it!!!
I was told a 4" lift was needed to go to a 35" tire 12.50 width.
So I think it is the width that might be the problem.
A level is fine. At 11.5 you might make it but it will be seriously tight if you do.
Do you know what size you have exactly? 295/65R20? I have 285/65R20 with the exact same level setup you have (2.5/1.5). Stock rims. My tires are about 34.5/11". They fit just fine with some room to spare. People have definitely been able to fit larger tires on stock rims with that level.
Discussion Starter #5
295/65/20 is what I was thinking. Linkin Hawkz I have the same truck like yours (I saw your thread with your tires and level) and I just want a tad bit more than the 285/65/20. Thinking the toyo at2. I just dont want to have to deal with any rubbing. Thanks for your guys responses
Most likely will be fine esp with an AT tire instead of an MT. The height will be no problem and the width should fit, although close to the UCA
Guys on this board have run 295/65R20 and didn't mention rubbing. I think that size with the Toyo Open Country AT2 is a great choice.
Discussion Starter #8
thank you guys for the response. I will post update photos hopefully here within the next month.
Some Assembly Required
35x12.50x20, no rub:
on a 2.8" level.
I run 285 65 20 KO2s (with Bilsteins at 2.1) and they only rub at full lock while reversing. There's a fingers width of clearance behind the tire.
Hi guys,
Thanks,
I have 2014 Laramie on 35/11.5/20 nittos and 2 1/2 level with no issues
Also just put same tires on my new 2019 Laramie with 3” lift level also no issues.
I am running bilstiens at 2.8 with 1.5 " spacers, 35-11.5.20 ridge grapplers on stock 20s, no spacers with 0 rub... 2017 1500
1 - 12 of 12 Posts
