1 - 2 of 2 Posts
I am going to replace my factory 3rd brake light (high mount stop, etc.) with an LED one from amazon. In my father’s 2010 F-150, that light leaked a ton and caused water to get into the cabin and stain the headliner and rot the cab corners from the inside out. Does the 4th gen ram have a similar problem? should I silicone it just in case or will i be fine to rely on the regular seal? thanks in advance
personally, I would use a light film of silicone. the rams can have issues with the factory light, so if your going aftermarket, i would... JMTC.
1 - 2 of 2 Posts
