1 - 3 of 3 Posts
· Banned
Try lurking around on Dodge Forum and Dodge Talk. A few builds running around. Air Ram has a conversion set to use the blower setup from a 4.6 ford, there is also that wild assed intake manifold. H/O cams (if you can find them) would be a big help, as would the later (08+) intake manifold. You won't be able to use the later cyl heads though. You may be able to find HO cams in a junkyard. Certain models of Grand Cherokee from 02-04 were built with the HO, different cams and intake manifold. This engine was rated at 265hp vs the standard 235hp. Everyone seems to agree that for a street truck, the HO cams are the better ones to get.
1 - 3 of 3 Posts
