1 - 6 of 6 Posts
^I agree if you have the right plug then that's about as good as it gets. Now using a poor plug could negatively affect things, for example I put E3's in my s10 and had stumbly idle and poorer performance it seemed. Mpg also seemed slightly lower, I switched to the stock plugs and ran normal.
^In addition to what he said, heat ranges can make a slight difference in power I believe also though.
Some Assembly Required
Use Bosch, Autolite or NGK. Copper core on the top bank, Iriduim on the lower.
1 - 6 of 6 Posts
