1 - 11 of 11 Posts
Discussion Starter #1
I’m currently running 33x12.5r18 on my truck with -24 offset on stock suspension and want to lift 4”. Does anyone run 33’s on a 4” lift?? Would love to see some pictures. I will eventually go to 35’s but don’t want to look super awkward on the 33’s for a while as they still have a lot of tread life.
You will have to change axles too (front anyway) you can also do a body lift only and 35s, I've got a 91 on 35x12.50 r15s on body lift only and it does the job and looks good. 4-6" body lift and the tires will fill those fenders nice...
Premium Member
Here is my truck before the 35's with the 4" Mopar lift kit. These are the stock 33" tires and wheels.
133733
Premium Member
When I added the 35's I put 11.50x35 on the stock rims, had no issues with rubbing at all. I have since added 12.50x35's on Moto Metal rims with -24mm offset. I have no rubbing issues at all, it's a great fit and nice look.
133742
I’m currently running 33x12.5r18 on my truck with -24 offset on stock suspension and want to lift 4”. Does anyone run 33’s on a 4” lift?? Would love to see some pictures. I will eventually go to 35’s but don’t want to look super awkward on the 33’s for a while as they still have a lot of tread life. View attachment 133724
133755
Running 35’s using 4 inch leveling kit.
I have a 6” Fabtech lift and love it...
133756
Top is level with 33's, bottom is with 35's (rubbed at full lock)....few months later I put the 6" lift on and 1/4 spacer on the front
133757
133758
Discussion Starter #10
Appreciate all the replies and pictures! Think I’ve decided to go with a nice Bilstein set up for now until the 33’s get worn down. Then will def do 4” on 35s
1 - 11 of 11 Posts
