I have a 2014 Ram 2500 6.7 cummins SLT. I recently replaced my center console from a bench seat to a floor console. During the installation I forgot to unplug the negative terminals from the batteries. When I finally put everything back together the check engine light and airbag light appeared on the dash. It's also indicating that the rear passenger door is open(which is clearly not). The driver and passenger windows will not roll down but the rears will. I also noticed that the outside temp is reading -40 degrees. The uconnect doesn't want to power on either. I took everything back apart to double check the connections and everything seems to be correct. I tried checking the fuses and they all seem to be fine. I replaced the BCM( body control module) thinking that might be the issue and still no luck. Has anyone ran into something like this?? PLEASE HELP!
