1 - 5 of 5 Posts
I jumpered the wires on the CAD to see if the switch was bad. Still no 4x4 light..
I'm pretty sure the light is an LED in the cluster. any other thing I can check since jumping the switch did not turn the light on???
just trying to figure this out.
thanks
I don't think in 01 they used LED's. They are just normal bulbs, pull the cluster and test the bulb.
I know this is an OLD thread but wondering where you found the broken ground wire. 99 Dodge Ram. I'm having the same issue, no light but 4x4 is working. Replaced the switch, jumpered the wires, still no light. Seeing 13 volts at the switch. Thanks.
'95 2500 8.L 4x4, '03 1500 5.7L 4x4 OffRoad, '85 W350 5.9L, '02 1500 Sport 5.2L
I have no real idea what the ground issue discussed here was. I have either a '98 or '01 service manual uploaded to 4Share. I would guess the '98 is closer to the wiring diagrams you need. If you'd like a copy and maybe some help tracing it out, send me a PM.
1 - 5 of 5 Posts
