1 - 6 of 6 Posts
Discussion Starter #1
I have a 2007 ram 1500 with hemi. When I'm in 4hi and 4lo there is a hard pop when under stress. You can hear it aswell as feel it. This is my 1st dodge and not sure what I should look for.
Premium Member
Does it do it on hard pavement & off road in sand, mud, snow, ice ?
4 wheel drive should not be used on hard pavement during a turn
If you are refering to full turn, it means you don't need to be in 4WD. You are getting to much traction and causes the gears to bind. If you continue it pops and eventually will destroy your transfer case.
Discussion Starter #5
It pops once I got into soft sand on the beach and I was going straight seen on another post about Ray shares being different on front pumpkin versus rear pumpkin before I bought the truck car lot put a another rear end on it and I don't know if the ratios not matching would have something to do with it
Premium Member
Different ratios between the front & rear differentials will definitely cause popping
It is also going to break something if you continue to use the front differential
1 - 6 of 6 Posts
