1 - 14 of 14 Posts
Hi all,
I have a a 2014 Ram 1500 5.7 Hemi with close to 79k miles. I've had this truck since new and I had no complaints about it until recently when the check engine light turned on and my truck would stall/turn off/EVIC system would display a message somewhere along the lines 'Shift to P to start' or 'Select gear to Drive'... This all happens when I come to a full stop at a red light or a stop sign. Has anyone else experienced this? Could it be an easy DIY fix or should I take it to the dealership to get it done?
:4-dontknow:
I had this problem on my 05 and it was the EGR valve, easy replacement. You could also run some fuel system cleaner through there that might help.
Also check if your battery is healthy. Low voltage during normal operation can bring all sorts of mystery gremlins to life.
Super Moderator
2009+ 5.7 Hemis do not have EGR, when they added VVT it eliminated the need
p0455-evap purge system large leak
p0456-evap purge system small leak
p0641-sensor reference voltage 1 circuit
Chris
Premium Member
Mine would stall at the red light but I never got any lights. It was my throttle body and it cost $400. Not happy.
Sounds like there is a large vacuum leak somewhere in your system. Shouldn't be too hard to find. With it running you should be able to hear it if it is a large vacuum leak.
Super Moderator
Trust me...it will come back sooner or later. EPA is cut back but not eliminated.
Maybe, but our trucks don't have it so I would not go troubleshooting EGR problems on them
Discussion Starter #13
Did the smoke test and confirmed the culprits of the problem - EVAP Canister and Purge Solenoid.
Can't believe i'm replacing this so early in my truck's life. It is what it is.
That is a bummer. Did they happen to say what, if anything, could be done to prevent something like this happening? Or is it just one of those one off things? Glad to hear they got you fixed up regardless.
1 - 14 of 14 Posts
