1 - 4 of 4 Posts
I want to get my truck leveled up. I measured my rake and it’s exactly 2”, but I’d like to leave a little rake. I’ve done a ton of searching and can’t find anyone who makes a 1-1/2” leveling kit for the 5th gens. I’ve found some for the 4th gens, and have read that they should work on the 5th gens but if that’s the case why aren’t they listed to work on them? I know that I could go with Bilsteins set at 1.7 but I’m trying to avoid that if possible just because for my use it’s really not necessary. Does anyone know if there is anyone who makes an 1-1/2” level kit for the 5th gens, or if the 4th gen ones will work on the 5th gen? Any help is appreciated, thank you
Discussion Starter #2
If anyone has used a 4th gen leveling kit on a 5th gen I’d love to hear from you. Thanks
I would recommend using a leveling shock like the Bilstein 5100s. For the 2019-2020 models there are 7 different height setting to chose from. Stock height, 0.5", 0.9", 1.3", 1.7", 2.2". 2.6". I recently put them on my 2019 at the #5/1.7" setting as I wanted to keep some rake as well. So far they've been great, glad I did it. I also used the 5100s on a 2009, 2012 Ram and the Fox 2.0 coil overs on a 2014 Ram. All set to or just below level keeping around 0.5" of rake. RP has these you may be interested in LIFT KITS :: Two Inch (Levelling) :: 2019+ Ram 1500 ReadyLIFT Leveling Kit - Performance Truck Parts
But I would definitely recommend the Bilstein B8 5100 part# 24-232203. I know the suspensions are different from 4th Gen to 5th Gen.
1 - 4 of 4 Posts
