1 - 2 of 2 Posts
2020 Ram 1500 Laramie 4x4
Discussion Starter #1
My 2020 Laramie’s led reverse lights appear to be bright enough until you are trying to backup in the dark. I’m finding it extremely difficult to back in to parking spots at night using either my mirrors or the camera.
Have any of you noticed similar issues? If so, have you found a work around?
Please don’t crucify me if this issue has already been addressed, as I was unable to locate anything while searching. Thank you all in advance!
Reverse lights are not designed to light up the area like headlights are but if you want more light then your only option is to install a set of aftermarket lights on the rear to light up when you are in reverse. I have seen some that you have to mount under the bumper so you loose ground clearance and I have seem some that mount in a bumper so you would either have to buy a new bumper or cut out your bumper to fit the lights.
1 - 2 of 2 Posts
