Just wondering if anyone knows how much horsepower would be safe to add to the hemi with the stock 65rfe tranny.
Source: http://www.allpar.com/mopar/transmissions/545RFE.htmlThe next six speed derived from the 545RFE was the 65RFE, used with V8 versions of the Ram 1500, Durango, and Grand Cherokee. The 65RFE only has six forward gears in ERS/AutoStick mode or kickdown mode; it is essentially a software and name change, which allows people to reach the “prime” gear via ERS as well as than kickdown. An internal Chrysler communiqué to dealers summarized the change in a similar fashion.
Engine output figures are given as net HP and torque, that is with all accessories mounted and numbers taken at the crank. This is the way every manufacturer does it and no vehicle is making those numbers at the wheels because there are parasitic losses incurred when that power is transmitted through the drivetrain.While the numbers might be correct when mopar numbered there RFE transmissions. How do you explain the build sheets that list the 6-speed as a 645rfe? That transmission, by your numbers would have the same 450tq rating as the 545rfe... There was no 65rfe, it's the 645rfe transmission for 2012.
Probably the tune. You were already only 3 lb-ft short of the max capacity and any adjustments to shift points can reduce its ability to handle the outputI just found out the hard way the torque rating of the 65rfe. Nuked the torque converter, 2nd and 4th gear clutches. Had it rebuilt right though. New updated TC, transgo shift kit, line booster, and new clutches. Have LSD 3.55 rear end. My mods that the tranny couldn't handle include, bbk shorty headers, k&n full CAI system, edge tune, pedal commander, and magnaflow cat back. Stock trans couldn't take it and committed suicide after 30000 miles. Upgraded rebuilt trans should handle it better and would recommend doing trans first, power adders later. Cost me $4700 CDN after tax. Food for thought for anyone chasing more power.
Agreed.Probably the tune. You were already only 3 lb-ft short of the max capacity and and adjustments to shift points can reduce its ability to handle the outputI just found out the hard way the torque rating of the 65rfe. Nuked the torque converter, 2nd and 4th gear clutches. Had it rebuilt right though. New updated TC, transgo shift kit, line booster, and new clutches. Have LSD 3.55 rear end. My mods that the tranny couldn't handle include, bbk shorty headers, k&n full CAI system, edge tune, pedal commander, and magnaflow cat back. Stock trans couldn't take it and committed suicide after 30000 miles. Upgraded rebuilt trans should handle it better and would recommend doing trans first, power adders later. Cost me $4700 CDN after tax. Food for thought for anyone chasing more power.
