1 - 7 of 7 Posts
Hey Doc sorry my inbox was full
Sure here is a link to it https://parts.moparonlineparts.com/oem-parts/mopar-release-lever-68044867ad
I will message you a code you can use.
Thanks,
Benny
Thanks,
Benny
I need a cable end connetor for the Cellular/ connection to my 8.4 radio u-connect 2014 1500 Ram. Can you give me a part number for that connector alone---I don't want to replace the entire harness--that's work. Thanks
Mopar Online Parts
If this is the harness that runs up the A pillar I believe its part # 68148260AC
128766
Does that look correct?
-Benny
The purple or Maroon connector in the mid to upper left of the pix is right --that looks like the one I need. What is that type called? Thanks for the pix---can you get that connector?=without the cable?????
1 - 7 of 7 Posts
