You have to make sure your dimmer switch is in the correct position. You start by rolling the dimmer all the way to the left as the starting point. Then roll it to the right until it stops without clicking to the next setting. That should fix it for you.
Thank you for the advice. It appears to work now although I noticed the light sensor is very sensitive.You have to make sure your dimmer switch is in the correct position. You start by rolling the dimmer all the way to the left as the starting point. Then roll it to the right until it stops without clicking to the next setting. That should fix it for you.
