Well as I alluded into my earlier post after finagling my truck into the garage (http://www.ramforumz.com/showthread.php?t=235162) I decided to change my transmission fluid today. Video I found helpful:
https://www.youtube.com/watch?v=mNo9Ln5KrOE
I basically just followed his instructions
So it starts pretty simple. I had all the tools I needed (T40 torx for the pan bolts, 8mm hex for the fill plug), the parts (transmission pan and Lifeguard 8/Mopar 8&9 speed fluid. I actually didn't have a 10mm hex for the drain plug but it was blocked by the Y pipe anyway so I dropped the pan like the guy in the YouTube video did.
Started out by taking out the fill plug; good grief that thing was on tight! I was using an 8mm box wrench around an 8mm drive socket because the ratchet made it too long and tried turning it, that didn't work, so I tried a Hammer. Then I ended up just forcing it with my hands when that didn't work-pushing up from the ground. By the time it broke loose I thought I had snapped my wrench. OK, got it out and it started puking fluid which was fine because I had my drain pan ready.
Next it as time for the pan bolts. They aren't super tight and are easy to get off, except for one of them-which is also right above the Y-pipe:doh: I had to use a box wrench to turn my T40 bit to get it off (and back on) talk about slow going. Loosen the bolts from one end of the pan at a time so the fluid spills out in a controlled manner. I didn't spill a drop. Pull out the pan and you have this here
Mmmm, look at that valve body. Cleaned the mating surface of the gasket and ran a bead of fluid around the new gasket (I guess you're supposed to do that like with an oil filter). Stop to admire the old filter:
And the magnets (Was a little surprised how much fuzz there was, but not really any floating around the fluid so that's good).
After the fuzz was scraped off:
There is a torque sequence you need to follow, I found it on another forum but can't link to it here; just Google 8HP70 torque sequence and it should come up on a BMW board.
Then it took about 3 quarts of fluid before it started to run out of the hole, fired it up and ran it through the gears, and it took two more.
Then I let the trans cool back down to about 100*F and opened the fill plug, fired up the truck, filled it till it dribbled, and put the plug in for good. I will let y'all know how the test drive goes.
I'd like to thank ArmyofOne for beating me to 66,000 miles in his 2 year newer truck and doing this before me
. I figured I'd be a forerunner of the 8 speed transmission fluid changes since I got a very early one. Apparently I don't drive enough though so Army had his review to put my mind at ease when I was doing this.
Please let me know if y'all have any questions; FWIW I just dropped the pan, replaced it and filled it. I do not believe in flushes so I didn't do one. Took right about 5 quarts, so buy six to be on the safe side.
