Hello. Recently my truck engine dies when brakes applied. Electrical problem not vacuum!! No rear brake lights or turn signals. Rear cab light works. With ignition switch turned on(engine not running) rear running and tag lights dimly illuminated. Engine on no rear lights. If brake petal applied kills motor. Front turn signal work. Headlights kill motor. If running and rear bulbs removed kills motor !!
Will not restart unless lamps reinstalled. Battery and alternator good. Removed all grounds cleaned and reinstalled. Brake pedal switch replaced. All fused checked and are good. Ignition switch replaced. Towing tee removed. Rear harness plug. Cleaned and reinstalled. Been working on this truck the last 5 days. Driving me nuts. Any ideas??
