1 - 3 of 3 Posts
Discussion Starter #1
I have a 95 Ram, AC Condensation leaks into cab instead of/or in addition to draining outside. So much so that we decided to rip out the constantly wet carpet and place grate on passenger side under a floor mat so that items would not get wet if placed in floorboard.
How do I find where AC condensation is designed to drain and check for plugged drains?
Thanks,
Jim
Wish I could be of more help but the only thing I can contribute is, get under the truck and look up around the frame on the passengers side just in front of the firewall to see if you can see the drain hose/tube and go from there. May try you tube for any videos on this subject.
Google search "2008 dodge ram ac drain" and a lot of information will come up.
I see you have a 95 so you might want to google 1995 instead of 2008.
My 96 was on passenger side, on the firewall. It is about 8 or so inches over from the frame and up like 16" up from the flat/horizontal floor. Unfortunaly a lot of companies just want to put a straight tube about an inch or so out from firewall. We use to take a spakplug boot and put it over it and make a 90 out of it so it didnt clog with dirt.
1 - 3 of 3 Posts
