1 - 3 of 3 Posts
Hi, I am having my transmission give me a problem on my 95 Dodge b2500 5.9 V8.
Basically when I put it in Drive it won't move but it wants to, just seems like it's not building enough pressure or something 🤷. I can manually place it in 1st and moves just fine and can shift to second and into drive and drives just fine, also reverse works as well.
I am thinking it's the governor and the pressure sensor solenoids, but when I open the transmission mine looks different from the photos I've got. If someone could help me figure this out I would appreciate any help. Thanks
Motor vehicle Automotive tire Automotive air manifold Auto part Automotive exterior
Tire Automotive tire Wheel Motor vehicle Tread
Automotive tire Bicycle part Bicycle chain Rim Sports equipment
Automotive tire Motor vehicle Alloy wheel Automotive design Rim
Motor vehicle Font Auto part Line art Automotive exterior
Automotive tire Motor vehicle Rim Bicycle part Font
Organism Font Schematic Auto part Pattern
It's a 95 witch is a RH not a RE that means it's hydraulic not electronic. All you have is a lock up and od solenoids. Did you find any debris in the bottom of the pan? The fluid is fairly dark.
1 - 3 of 3 Posts
