1 - 3 of 3 Posts
Gentlemen,
Have a low mileage 318 from a jeep available.
What can I anticipate to change for fitment into my 98 Ram?
harness? Intake? mounts ?
Thanks in advance as all of you are extremely knowledgeable and are without a doubt, "headache savers!"
· Banned
I think the easiest way to explain it is...it's a long block replacement.
The best way to do it is to add a day to the swap and do a side by side.
Half of the electronic connections are going to be different, and the intake vacuum lines. you can either plug one or two or add a "t" on the passenger's side. Exhaust manifolds, and a couple other small things.
I've got a '95 and if you decide not to swap it for an hour or twos worth of work...
Let me know, I'm accepting donations.:50:
Between the 96 and 98 they are different, all the sensors will need to be swapped out to the 98 sensors. Even the 3 sensors on the TB.
1 - 3 of 3 Posts
