1 - 6 of 6 Posts
When I turn on my left turn signal they flash fast. Right turn signal works fine as do emergency flashers. I've inspected and replaced the front and back left turn signal bulbs. I did notice that when I raise the hood, as soon as the underhood light comes on the front left turn signal glows faintly. I imagine there's a short somewhere but I'm not sure where to begin looking. Any ideas?
Thanks
Discussion Starter · #3 ·
I disconnected the underhood light and still have the same problem. I also tried removing and cleaning up a couple of ground wires I found in the area of the front left turn signal. When I disconnect either of the grounds the turn signal light is still on. Does anyone know where the ground for the front left turn signal is?
Thanks
· Banned
Not off the top of my head.
However, if you can isolate the ground wire from the park/turn wires (should be easy) try running a temporary fused ground to the body and see if it helps. You can, if you choose, just cut the factory wire, run the temp, and cap off the factory ground.
1 - 6 of 6 Posts
