So, I needed to replace a leaky rear drum break cylinder and have noticed there is excessive play in the hub bearing. I can actually wiggle it up and own and see it move in the bearing. I want to replace the bearings but on the end of the outer hub is a metal plate with a hole in the middle behind which I assume is the hub nut.
Anyone know how to get that plate off? I am completely lost, it's not like the usual tap off dust cover I'm used to seeing.
HELP!!
HELP!!
