Awesome work, Joe! Keep it up!
Thank-you sir! In all honesty, I didn't think it would get this involved, but I knew when I started it wouldn't be a small project either. My budget for this is next to nil, so I have to do the work myself, as time and money allows. I also realized after playing with this truck for 20 years that it would be impossible to remember what parts came from what vehicle without putting it "on paper" somewhere, (like when I had the '74 Camaro front clip, using a 1985 Olds rear end and 200-4R transmission).What a badass project, thanks for posting such a detailed thread!!
Thank you sir! I'm looking in to getting a gas bottle for my MIG welder so I can run straight MIG rather than gasless FLUX core wire. The FLUX core is ok down to 16ga sheet metal. Anything thinner and you really need to have the wire speed up and move quickly to prevent burn through or puddling. With the straight MIG wire, I can go as thin as 24ga sheet metal and not have all the spatter and slag that is left behind by the FLUX wire. In the long run, it will save me a bunch of clean up time.Nice work, Joe!
The links are coming up with an error.Ok, just a little update...Since the last login, I've done some more work on the cab floor and added the hole in the transmission cover for the transfer case shifter, reusing the stock Dodge boot. I also built up a winch mount for the front, using the two stubs inserted in the Dodge frame end and some old diamond plate I had on hand.
http://s257.photobucket.com/user/No... a NAPCO build/transmission cover flange.jpeg
http://s257.photobucket.com/user/Noble413/media/1957 Chevy Not a NAPCO build/transfer case boot.jpeg
http://s257.photobucket.com/user/No...a NAPCO build/backup saw and tread plate.jpeg
http://s257.photobucket.com/user/No...t a NAPCO build/winch mount construction.jpeg
http://s257.photobucket.com/user/No...vy Not a NAPCO build/winch mount painted.jpeg
http://s257.photobucket.com/user/Noble413/media/1957 Chevy Not a NAPCO build/tow hook mounted 1.jpeg
http://s257.photobucket.com/user/Noble413/media/1957 Chevy Not a NAPCO build/cab wall welded.jpeg
http://s257.photobucket.com/user/Noble413/media/1957 Chevy Not a NAPCO build/blank cowl.jpeg
I also replaced the louvered cowl panel that had been chromed by a previous owner with a blank panel to keep debris out of the vent area of the cab, which should help control rust issues in the future. The mid-50's Chevy cabs have a fresh air channel below the bottom of the windshield, that is ducted in to the kick panels in the cab. Water in this area will drain down to the corners of the firewall and in to the rears of the front fenders. Debris collects in this area, block the drains, which leads to rust.
The last thing I did was weld shut a hole in the left rear corner of the cab. I'm guessing someone ran an antenna cable trough this hole at one point. It's welded and rattle canned for now.
I've started sorting the engine wiring with the help of the big yellow book. There are no pictures yet, but my goal for 2017 is to have this truck moving under its own power, on the factory fuel injection.
-Joe
D'oh! I'll get it sorted. Photobucket was giving me fits yesterday.The links are coming up with an error.
good to hear about progress though
Ive debated doing this and is awesome to find someone who is actually doing this... I love the older style trucks and the newer style comforts. Great job !!!!
