I've been making progress the past month or so now that the weather is clearing. My emphasis this year is to get the truck moving again under its own power. I think I have a handle on the basics I need to have the wire harness and computer operational and even though there is more sheet metal work left to do, moving without towing will make the metal work easier to accomplish.
I got some unexpected funding this year, so I went through the engine as much as I could. There is now a new, albeit computer friendly, camshaft, along with a double roller timing set and a timing chain tensioner. The plenum gasket on the stock intake has been replaced, as have the front and rear seals and the oil pan gasket. Internally, the engine looked to be in good shape. The bearings and journals all looked healthy, but I did install a high volume oil pump, just to play it safe.
While getting the engine sorted, I found two broken intake manifold bolts, common to the Dodge Magnum V8 engine. I was able to weld nuts to the remaining bits of bolt and once cooled, then spun right out.
-Joe
-Joe
