i just recently acquired a 2002 Dodge Ram 1500 5.9 and the odometer, speedometer don't work along with the abs and the brake light being on and the only code i have is P0500 (vehicle speed sensor A) i've replaced the sensor in the rear diff with no resolve. other potential symptoms are intermittent stalling (engine shutting off) with no obvious pattern which i was thinking was a bad ground so i repaired the terminal with no resolve and then i was turned on to the O2 sensor from my buddy, replaced those and that seems to have stopped the stalling for now. the transmission also seems to be having trouble not sure if its slipping or just having a hard time shifting due to the wheel speed sensor. any advice will be greatly appreciated.
thanks
thanks
