1 - 4 of 4 Posts
Discussion Starter #1
I have a 2014 Ram 1500 5.7 hemi, Longhorn, and I was sitting in a parking lot with the engine running and all of a sudden the ABS and Brake Light and traction control light came on. I have tried resetting the computer by unpluggi ng the power from the battery Nothing changed I was looking in the power distribution box, and found a 20 amp fuse broken where the F29 slot was. It looked like someone had stuck the wrong fuse in the slot and it is a square slot with different prongs. Any one have a suggestion, everything else works fine and no braking problems. But the error on the dash says Check ABS service soon. .
Check these fuses
F26 (30 amp-Antilock Brakes-Stability Control Module-Valves)
F76 fuse (10 amp - Antilock Brakes - Electronic Stability Control)
F06 (40 amp - Antilock Brakes - Electronic Stability Control Pump)
Discussion Starter #4
Did you ever get this resolved? I'm having the same problem. Thanks!
I had to take it to the dealer, I tried replacing some fuses, still didn't work. They had to replace the ABS module. Then They found some other issues..but none related to the ABS module..it was a factory recall..
1 - 4 of 4 Posts
