1 - 3 of 3 Posts
Hello everyone!
I've recently had a problem with my abs/traction control light coming on every now and then. I finally got sick of looking at the dash lighting up so I started searching and quickly found that it could be my abs speed sensor. Sure enough my passenger side tire was rubbing the wiring connecting to the sensor. I repaired it best I could and put a ton of electrical tape followed by some plastic tubeing to protect it. I have a tuner so I reset the bcm by programming a new tune in my truck. All was great for about 4 days and then the lights appeared again but this time they stay for longer than previous. I have brought my truck to the dealer when this issue first started happening as I am still under warranty but they said it not covered because of 35" tires which I had way before any of this started happening. If someone has any advice on what I should do or where I can get the correct part# for the sensor it would be greatly appreciated. Thanks in advance !
2013 ram 1500 sport
6" zone lift
3" pa
20x9 fuels
35x12.50x20 dick cepek
Diablo t1000 (always hide from dealer)
Read the DTCs from the ABS module, look them up and find out what is really going on. Once the cause is understood, then you may have a better chance at a final repair. There may other issue(s) besides the damaged wire which by itself would not cause a DTC unless continuity was lost.
1 - 3 of 3 Posts
