1 - 9 of 9 Posts
My 2017 SLT didn't come with a tow hitch but the tow bar is there i was looking at a Curt 13333 class 3 hitch i look very easy to install has anyone added one of these?
2015 RAM 1500 SLT 4x4
I got this one for my 2015 SLT Quad Cab. From E Trailer ! I have had good luck with them. I am sure they have one for your 2017! They have a install video and You Tube has a TON of install videos ! 2 people make it alot easier as they are frigging heavy ! A torque wrench is a Must, BUT for me I paid my mechanic 50$ to install so that made it real easy for this old fart lol. Most places will charge 1 hr labor. Since it is for towing I wanted everything to be right ! I also went with the Class 4 hitch which is overkill for my 1500 but IMO bigger is better :) and cost was about the same !
https://www.etrailer.com/p-41948.html
https://www.youtube.com/results?search_query=install+trailer+hitch++RAM
For a little more money I would go with the heavier full frame type just for piece of mind. Very easy to install and no hole drilling.
Moderator
I would go with at least a class 4 hitch. A class 3 is only good for 6000 lbs without weight distribution bars; 10,000 lbs with weight distribution. Very easy to get up to those numbers. Class 4 should make it a non-issue for anything you want to tow.
Premium Member
Super Moderator
Class 3s are for 4 wheelers and minivans, you want a class 5 with the 2.5"X2.5" receiver for an HD truck
Gotya.
I would echo the others above and say get a class IV at a minimum since anything with the Hemi + 8 speed has a tow limit that exceeds 8k or so even with a 3.21 rear end.
1 - 9 of 9 Posts
